I have been using what came with my 2017 Volt. At home, I plugged it into a 240V outlet (with an adapter), and at work, I plugged it into a 120V outlet at 8A. No problem for 20 months.
Now, when I plug the EVSE into the 120V outlet at work, and even at home, the green light on the EVSE shows that all is cool, but after I plug the other end to the Volt, no green light showing and the Volt isn't charging when I open the door to check the dash. I inspect the outlets, they're normal as I can power my leaf blower from the outlet.
But if I plug in the EVSE into my 240V outlet at home, it charges my Volt. My Volt also charges if I plug it into a Level 2 public charging station.
Has anyone experienced this? What could be wrong?
