My 2017 VIN indicated a GM recall (not sure if that counts as a NHTSA type safety "recall").
https://my.chevrolet.com/recalls
Called today, dealer says there are two open items, scheduled service for early next week. Thanks OP.
The following recalls have been found for your 2017 Chevrolet Volt
VIN: 1G1RD6S54HU117nnn (June 2016 build date, in service 6/30/16)
Results last updated: Aug 18, 2017
Recalls and/or programs for your vehicle in which repairs have not been completed are listed below.
Other Programs for Your Vehicle
What's this?
GM Program #:
N162070470
Date Issued:
Aug 15, 2017
Program Title:
No Start or Loss of Propulsion - Expires 9/30/19
Program Description:
On certain 2017 model year Chevrolet Volt vehicles, the high voltage interlock connector behind the high voltage battery disconnect relay fuse block cover may be susceptible to becoming recessed back into the high voltage battery disconnect relay assembly. This may cause an electrical disconnect which could result in a loss of vehicle propulsion and/or a no start condition. The malfunction indicator lamp may be illuminated and DTC P0A0C – “high voltage system inter-lock circuit low” may be set. A “Shift To Park” message may also be displayed. Additionally, a subset of these vehicles may have a condition in which the 15A fuse in the high voltage battery disconnect relay may prematurely open. The open fuse may prevent the low voltage battery from being charged by the 14v DC power module. If this were to occur, the vehicle will provide warning to the driver and eventually lose electrical power. Once power is drained from the 12 volt battery, the vehicle may lose propulsion and will not start.
Repair Description:
Reprogram the hybrid powertrain control module 2; and if applicable, replace the 15 amp high voltage battery disconnect relay fuse.
Program Status: INCOMPLETE
--Anyone know which fuse it is, and what part number? Is it a standard 12V, 15A plastic fuse, or one of the HiV fuses (maybe HiV, "15 amp high voltage battery disconnect relay fuse", or maybe it is a 12V fuse for the relay coil)?
