My car is not even a month old, about 1700 miles, but I'm pretty sure something is wrong with the climate system. It started on Monday night, and has gotten worse since then. I have my climate controls set to "max", and the temperature knob is on "hi". I do not have the defog turned on for either the front or the rear, and in the settings, I turned off the option for automatic defog. Only cold air, no heat at all, is coming through the vents. At first I thought it was my fault, that I had the settings set the wrong way. However, after reading as much info about the climate control system as possible, I don't think this is the case. I also thought it was just because it was so cold out (9 degrees F. tonight) that the heat wasn't able to catch up to the cold...but I had preconditioned the car before the trip, and it was about 15 minutes of driving.
In addition to no heat and cold air, I am hearing lots of strange gurgling noises; and sometimes a whining noise that sounds a bit like a teakettle heating up. I will be talking with the service dpt. soon, but before I do, does anybody have an idea what may be going on?
Thanks, Chuck
Thanks, Chuck
