Thanks Scott. I wonder if the OP ever got out of Service Mode.Service Only Mode -- Learned about 'Service Mode' the hard way: Any...
They won't perform the recall or anything else because they have been used beforeI would strongly caution against trying to externally warm the battery. More than likely the actual temperature has nothing to do with your troubles. It's most likely a failed sensor. If you hook up a diagnostic tool and check the temperatures being reported I'd bet one of the 9 will read -40, indicating a failed sensor. The recall will allow that sensor to be ignored.
In 2019 my family was blessed to be given a 2012 Chevy Volt from a friend.
The car has been sitting, plugged in, for two days. It will not start. It says 'battery too cold plug in to warm'. I've talked to Chevy Advisors, because of the year and mileage, the warranty is no longer existing. I've read everything I can on this issue, and have found nothing to work. I do not have the money to have it towed and a dealer look at it.
There were battery temperature sensor codes. I've disconnected the 12v and left it off overnight. I've held the power button for 5 seconds. Tried to jump it. Checked all
Fluids. Is there a way to bypass the codes? My husband has a code reader and I tried to clear the codes. Even after disconnecting 12v as soon as power turns on, check engine light turns on.
Side note... It's not been that cold. Has showed maybe twice. Where I park, the vehicle is blocked from pretty much all wind, weather from the sides.
What can I do? This is my only vehicle. I can't afford a dealer. I can't not have my car! I am a instant cart shopper and delivery person. Sitting here not making money is driving me insane!
@JMcAmis16 ,They won't perform the recall or anything else because they have been used before
I have tried many ways. I press on break , press power button, the screen circles and says initializing. Everything except the engine comes on. The air turns on, but does not get hot or warm. Screen shows "battery too cold"When message I turn the car off by just pressing the power button once, everything shuts off. And I can hear the battery fan/heater turn on. I have also not pressed the brake and held the button for a few seconds and everything turns on. Dash lights, radio, air etc. And it just says battery too cold. During both of these, I can not switch through the messages, navigation, different things on dash . Also..the car ALWAYS shows it is charging. But has yet to go over 2 mile charge. | ||||
Thanks for the clarity and reply. I'm afraid I don't have any suggestions except for my post above. I am sorry for you going through such challenging times.
What happens if you turn the car on as described, and then open the hood? This would normally start the engine.
I'm guessing this is saying the software recalls were already applied prior, which would show up when they pulled up the history, therefore it's not outstanding. That would eliminate the temperature sensor software fix noted. Honestly it may be best to sell it as a parts/project car.They won't perform the recall or anything else because they have been used before
Apparently I was not! I feel like such a dumba$$ 🙄Thanks Scott. I wonder if the OP ever got out of Service Mode.
That's awesome. Glad you have this issue resolved.Thank you to all of you who tried to give me tips and ideas. I really appreciate you taking the time. It is all fine now! Charging, starts right up, no MIL, I'm SO relieved! Thank you thank you thank you!! ❤
That is great. Just remember that it is an electronic switch and only requires a quick press and immediate release to ' boot ' the car's computers. Good luck with everything.... It's running right now. And seems to be ok. No MIL. no messages.
