Given that electric house wiring pretty much limits you to 100KWh battery packs because larger packs simply won't able to fully charge overnight (Tesla Models X & S 100D take 8.5 hours at 100 amps). Most home wiring is 240v 100 amp or 200 amp although older homes may only be 110v 100 or 200 amp. This means there is a physical size limit to EV batteries.
So now the question, given that DC motors are already 90% or more efficient, where else in the vehicle can we find efficiency improvements? This will be critical to continue extending the range of EVs. On the flip side of this if Chevy were to put a 100KWh battery into the Bolt simple arithmetic results in a 400 mile range on a single charge. This is on par with gas for range but still falls short of diesel for range.
