1 - 2 of 2 Posts
Short version no (due to distance from current infrastructure),
long version, if you put the volt into "hold" mode immediately after full charge, drove to the base of the mountain, then switched to normal mode, you "should" be able to make it to the top, and regen enough charge on the down trip to get you where you want to go.
1 - 2 of 2 Posts
