Yes, that is exactly right.I just leased a 2017 Volt LT. It is setup to charge at 8 amps immediately. If I plug in a level 2 (240v) charging cable does the car automatically detect the 240V and begin charging at the higher level-2 rate? Thanks.
Yes, the 2017 Volt communicates with the EVSE (Level I or II) to determine voltage and the maximum amperage. The Level I EVSE that comes with the current 2017 Volt is limited to a maximum of 12 amps. It turns out that this specific model of EVSE can be used with a custom power cable adapter that enables the 2017 Volt's EVSE to be connected to a 240V outlet. This provides the benefit of quicker Level II charging, however it will still be limited to a maximum of 12 amps. The maximum Level II charging amperage that the Volt can draw is approx. 15 amps @ 240V so a dedicated Level II EVSE needs to be able to supply 16 amps and would be rated for and require a minimum of a 20 amp dedicated circuit. When installing a new 240V circuit many choose to future proof the 240V circuit by installing a 240V breaker, wiring and a receptacle (such as a NEMA 14-50R) rated for 50 amps. Just to confirm, when charging at 240V the Volt will charge at the maximum amperage supported by the Level II EVSE up to a maximum of 15 amps. E.g, if you connect the Volt to a Level II EVSE that is capable of 240V and 32 amps the Volt will still only draw 15 amps maximum. In the future you might own a plug-in vehicle that charges at up to 32 amps or more.I just leased a 2017 Volt LT. It is setup to charge at 8 amps immediately. If I plug in a level 2 (240v) charging cable does the car automatically detect the 240V and begin charging at the higher level-2 rate? Thanks.
I don't think this is true.The Volt will always charge at the maximum rated power unless you're plugged in to the Voltec EVSE
Re: "The Volt will always charge at the maximum rated power unless you're plugged in to the Voltec EVSE"I don't think this is true.
