I think we have a few things in the news that just might balance each other out, if we're lucky:
1) Around 4.5 Billion recoverable barrels worth of shale - North
Dakota (discovered in 1995 but the assessment was increased). Very difficult to extract, harder than tar sands. Will start seeing real oil in 5 years.
2) Around 33 Billion recoverable barrels worth of deep well crude - Brazil. Will start seeing real oil in 5 years.
3) Russia seems to have reached peak - last year's 10 mbd should be highest production number reached - Number two world producer of oil.
If Russia starts to fall off now finds 1 and 2 will not help us. If Russia can hold on for 5 more years before falling off finds 1 and 2 will probably not be enough to hold us at current levels, assuming everything else stays the same. Projected max output from the Alberta tar sands is 5 mbd which will be reached around 2015 or later. Same for Ven.
However, as the poster above wrote this oil will be a lot more expensive. Cheap oil is a thing of the past.
