pnieder
You seem to be chasing ghosts with your article and the rebuttal hear. Most of your last post was spent pointing out some common misperceptions regarding electic only or seriel hybrid transportation, but none of those were mentioned on this thread.
I, too, have been very disappointed with GM's choices for product development. This disappointment is not because I think they should have forsaken profitable business decisions for questionable ones that benefit humanity or country, but rather because they missed a business opportunity that also carried those benefits. I have been convinced for a long time that electrical propulsion is the drivetrain of the future, and it also should be much more the drivetrain of the present than it is. There are many benefits to the EV drivetrain as I imagine you already know, and the biggest benefit is the ability to efficiently use stored electric energy. This does not mean it needs to be a BEV only as many others believe, although they may end up being the best long term solution. Plug-in hybrids with an electric drivetrain and fully capable stored electric range sure seem logical to me and put passenger much farther along the path of development than even Toyota's HSG. Toyota and you appear to recognize this with the announced path to a plug-in vehicle. The only problem is that they will have to increase the battery significantly, add charging capability, increase the power electronics, increase the motor, etc. This is not really a continuation down one path as it is a jump to another. Guess which other path that is? In my mind, as well as yours and Toyotas apparently, it is the path the Volt will be on if it does get produced.
I am neither a GM enthusiast nor Bob Lutz proponent, although he did see a good thing when it hit him in the face. The good thing being the Volt and I don't believe it hit him in the face until after the Jan '07 unveiling. I believed then it was a last minute, makeshift prototype that adapted from the E-flex platform they were devolping for hydrogen fuel cells. They saw Tesla, rising gas prices, and public sentinent and dipped their toe in the E-Rev waters. If they had put much thought and effort at that point, I don't think it would have been announced as a Chevy nor as comfortably under $30K. I said then and still believe that had they really intended to produce the vehicle, it would have been branded as a Cadillac. Since the response was so significant, they have pushed forward. They are still struggling with the tight wiggle rooom that a Chevy branded vehicle affords them. Changing the outlook to $35K seemed resonable given the technology and I think they may be able to sell it for up to a few thousand more, depending on market conditions in 2010. They know $48,000 is out of the question, regardless of what their costs are. They have been building cars long enough and have done enough work with batteries and the E-flex platform to have known within 20% of what the costs would be. The price bantering seems more like strategy than honesty and the price will end up being what they feel the market will bear. If that means it is sold for no profit or at a loss, how would it be different from the early years of the Prius?
It wasn't so much the figures that you used to base your analysis on as much as the missuse of them and the ones you had to have walked over to get to them. What about using a more realistic average range. Did you here 32 at normal highway speed with no AC from a GM engineer or did that come from the Yahoo article that said only 32 miles free highway driving? If from Yahoo, then lets assume it is true but drop your assumptions about other conditions. GM has also mentioned 40 miles end of life for all normal driving conditions, as well as around 50 beginning of life. You must have seen this. So pick a reasonable number for average range. Even $5 average gas cost from 2011-2021 seems a little low to me, don't you think? Wouldn't it be more relevent to use the average inflation rate for gas during a the past 10 or 20 years and take the arbitrariness out of the equation? Go to Toyota's website and look for pricing on the 2008 Prius 1226 model. This is how I found 5 versions of it for $26,400 and more. This model is more comparable to what GM has announced for the Volt. What happened to the battery range on your longer trips calculations? Also, do you think that absolutely nobody will have access to daytime charging, because you account for no effect from this on electric miles?
You wrote, "I was very excited about the Volt when announced. I am waiting for a personal EV, when one is available that is cost-effective."
If you truely believe this, then you should be cheering on the Volt, Tesla, Fisker, MiEV, et al in spite of your dislike for Mr. Lutz. These vehicles will push advances in battery technology and the electric drivetrain with far more force than the Prius. The natural evolution for technology is to start towards the higher end and work it's way down. Toyota's HSG was a bit of an exception because it didn't really offer much advantage for the high end.
