Between yesterday at 5:00pm and today 4:24 pm I drove a total of 116 EV Miles, hope the timing is good for Volt-Stats to reflect the achievement.
How can you have used 26 kWh? Max usage is around 14.x kWh from one charge, right?Between yesterday at 5:00pm and today 4:24 pm I drove a total of 116 EV Miles, hope the timing is good for Volt-Stats to reflect the achievement.
I drove yesterday to my astronomy observing site located 30 miles from home, the highway is not good for EVs, it has numerous small hills that suck your electrons (typical of the Mississippi highways), i got back home at 32F with one mile left on the guessometer for a total of 59.4 miles and 14.0 KwhHow can you have used 26 kWh? Max usage is around 14.x kWh from one charge, right?
If I were to recharge, overnight (to full charge) with 1 mile left on the GOM, my stats would reset. I think the issue is when you let it charge overnight, you didn't get to a "full charge" by the time you unplugged and drove again, correct? That would make sense... If that's the case, I guess it's just a different game to play with stats.I drove yesterday to my astronomy observing site located 30 miles from home, the highway is not good for EVs, it has numerous small hills that suck your electrons (typical of the Mississippi highways), i got back home at 32F with one mile left on the guessometer for a total of 59.4 miles and 14.0 Kwh
Huh, I wonder who holds the record for the most KWH displayed on the screen. This would require days of charging and pulling the plug before the battery is full. Does this field go to 3 digits? Ari_c, are you up for the challenge? The gauntlet has been thrown down!!!If I were to recharge, overnight (to full charge) with 1 mile left on the GOM, my stats would reset. I think the issue is when you let it charge overnight, you didn't get to a "full charge" by the time you unplugged and drove again, correct? That would make sense... If that's the case, I guess it's just a different game to play with stats.
I had it up around 70kw on a 2013 when it was very cold and I didn't have enough time on the charger.Huh, I wonder who holds the record for the most KWH displayed on the screen. This would require days of charging and pulling the plug before the battery is full. Does this field go to 3 digits? Ari_c, are you up for the challenge? The gauntlet has been thrown down!!!
Volt Stats did get the total mileageBetween yesterday at 5:00pm and today 4:24 pm I drove a total of 116 EV Miles, hope the timing is good for Volt-Stats to reflect the achievement.
Welcome to the Hall of Fame follow Tennessean. Twin Volts too.Volt Stats did get the total mileage![]()
