1 - 5 of 5 Posts
One of my 2012 Volts has been giving me the "Battery too cold, plug in to warm" message.
I took it in twice to the local dealer and after consulting with GM they determined that one section of the battery probably needs to be replaced due to a bad battery temperature sensor. But in order to do that the dealer would need a tool to drain the remaining charge from the battery, which costs $8,000 to $10,000.
The local dealer is not going to buy the tool, which is understandable. They called around to the other local dealers, but none of them have the tool either.
I was referred to Chevrolet Customer Service and I have a case open with them. It looks like I will need to go to bigger city to find a dealer that can swap the battery section.
I am in South Bend, Indiana. So Chicago, Indianapolis, and Detroit are within reasonable driving distance.
Has anyone in those cities had a battery section replaced? What dealership did the work?
Or, can you give me a dealership in one of those cities that sold a lot of gen 1 Volts that might have done this before?
Thanks!
I am surprised the Volt Advisor cannot set this up for you.
Discussion Starter · #5 ·
OK, thanks for the suggestion on the Volt Advisors.
I got an e-mail yesterday from the Chevy Customer Service rep and I am being patient with them for now. The good news is that the car runs fine and it only happens about once per week.
And I will give Cole Chevy a call as that is only about an hour away.
1 - 5 of 5 Posts
