Hello!
Long story short I got stranded in my Volt several times over the past month. Pressing the start button would result in "Service Battery Charging System" requiring me to find someone who I could jump start the car using the front battery terminals.
It's been at the dealer now for three days, even having a traveling Volt specialist onsite to figure it out. End result... bad cell in the 12v battery. Problem is they won't replace it for me under warranty as I have 49k on the car, and they say the 12v battery is only covered by 36k 3yr.
Due to how the dealer had been handling the situation I chose to walk and replace the battery myself since it's not covered. The GM Tech told me to make sure I get a Fiberglass mat Battery and not a lead acid because the charging system in the volt can send upward of 16v and if I use a lead acid they could only handle around 14v before heating up and it could cause problems.
Does anyone have a suggestion where I can source the correct battery type for my 2016 Volt other then the dealer? Model # or anything?
I know there is this post --> http://gm-volt.com/forum/showthread.php?279833-Chevy-Volt-2011-2015-12V-Battery-replacement-FAQ but it's for 2011-2015's so not sure if the info is the same or not.
