Searched the forum for anything having to do with navigation system problems and came up empty. I have a Gen. 1 2013 Volt that has developed a problem with the navigation system, specifically the map. First is that the system gets stuck in "Navigation initializing" for up to 1/2 hour after the car has been powered off for any length of time. Guaranteed to happen first thing in the morning after charging overnight. Then the direction arrow cursor simply spins in circles if not moving. Once you start moving, it can be several miles before the map updates and actual location is very far off. If traveling in a straight distance and direction for anything more than 5 minutes the location cursor while still spinning moves off the actual roadway on the map and make a counter clockwise loop before returning back to the roadway. Sometimes at the furthest excursion from the actual roadway, the location cursor "snaps" back to the roadway and continues its CCW dance on the map.
I took it into the dealer yesterday and they couldn't find anything wrong with the car. There are no fault codes set in any module. Of course the map behaved itself when I delivered the car to them because I had a 30 minute drive to get there. I told them how to get the system to flake out and after extensive road testing by the technician they observed a mild version of the problem. They still could not find any issue with car or software. They want me to leave it with them for a couple of days. I will do that once I have alternative transportation arranged.
I did discover something interesting in a 30 mile drive this afternoon while I played around with map parameters. It has been set on the simple 2D cursor orientation all this time. That means the cursor mostly spins CCW in a circle on the map. I switched it to 2D Heading Up and the problem changed where the cursor stayed in the same orientation but now the map itself rotated around snapping back and forth. This makes me believe the problem lies with whatever provides the compass direction to the mapping function.
I asked the dealer first off whether there was simply a faulty GPS connection to the mapping function and they said there was not. The DIC compass direction is always correct and does not deviate from actual true direction so believe the DIC compass indicator does not rely on the same compass input the map function does.
Has anybody had a similar issue or problem and can point me to where I should have the dealer do further investigation. The dealer said their search of the GM problem database yielded nothing similar to my problem. I am stumped so far and the same goes for the dealer.
