First DCFC charging experience......Not quite what I expected.
Made an overnight trip to PA and ended up doing some more local driving than initially planned, so I needed to hit a CCS station before heading home. Luckily there were 2 in the city I was in, so I headed for the closest one to me, an EVgo unit that I found out was a 100 amp one.
It was a streetside unit, which are very rare, but luckily it was open and so I parked, used my EVgo card and started charging.
HOWEVER, for the first 15 minutes or so the charge rate was limited to 18-24 kW and 60-80 amps. It was so slow I thought I had ended up with one of those 24 kW CCS stations.
It spent the first 10 minutes at 60 amps (350V), then slowly ramped up to about 80 amps the next 5 minutes, then after a couple minutes around 80 amps, it finally did a slow ramp to 100. I think the last 9-10 minutes I actually experienced 100 amp charging (~360V), with 35 kW as the highest observed charge rate.
Not sure why it took so long to ramp up to 100 amps (the station's max output)? My SOC was 16% when I started charging. Only charged 30 minutes because all EVgo stations cut off after 30. I ended at 33% SOC. Went from 32 to 65 rated miles in 30 minute.
I juuust had enough charge to make it home. Funny thing is the first few miles driving after charging on the way to the highway, my ranged actually INCREASED and inched up to 69 miles before ticking back down.
Temps were in the high 30s most of the day. My initial conclusion is that DCFC station just sucks?
