This time, I decided to do a quick test of a 125 amp DCFC Chargepoint station as my 2nd attempt at fast charging. Being a 125A CP station instead of the 100A EVgo station I got raped at with a slow (<35 kW) charge rate, and a properly heated HV battery, I would surely experience much faster charging speeds, right?? Ehhhhhhhhhh......
I drove out to the CP station that is ~16 miles from my house. Temps were in the upper 30's, but this time I tried to make sure the battery was heated up properly, and I ended up doing a half dozen 50-70 mph "floor it" runs, trying to heat the battery to a higher temp than last time. I'm not sure what the HV battery temperature was, but it had to be higher than my first time fast charging.
I arrived at the station with a 45% SOC, plugged in, and here were the results. I only was able to charge 15 minutes because the liquor stores were closing, and I had to "Bolt" to the nearest one to get booze for the night.
Here are the snapshot stats:
1 minute in: 22.1 kW
6 minutes: 25 kW
10 minutes: 28.1 kW
16 minutes: 35 kW
Beginning SOC%: 45
End SOC%: 54
Total of 7 kWh charged in ~16 minutes. It is 29 cents/kWh, but there was a $3.50 minimum charge, so since I had to leave early, I didn't get my money's worth. Still way cheaper than EVgo though. Didn't sniff ~44-45 kW, which I figured would be the max charge rate at a 125A station.
I have to add, driving back was very fun. Had to take some local roads, so the Bolt was getting slung into some twisty turns without any issues!
6 minutes: 25 kW
10 minutes: 28.1 kW
16 minutes: 35 kW
Beginning SOC%: 45
End SOC%: 54
