41 - 51 of 51 Posts
The Owner's manual only discusses one washer fluid tank. Perhaps, they run a tube to the back from it.
When I asked that question about the Bolt EV I was told that there's only one reservoir. My Prius C also has one reservoir that feeds both front and back squirters.
I removed the section in the rear hatch that holds the charging cable and towing bolt, and it looks like a Bose subwoofer is there (there is an embossed Bose logo on the left side of the plastic assembly). Guessing that the silver box with heatsink fins is the audio amplifier?
http://imgur.com/a/JG2Zt
Would be interesting to see what's here on an LT. the factory LT stereo is pretty good - wish I had remembered to try the premiere stereo more.
great photos, thanks so much for posting.
Banned
Those are great photos. I don't suppose you have any pictures of it sitting next to a Volt, from several angles, and maybe from above?
Has anyone ever had theirs on a repair shop lift and been able to take pictures of the underside?
Great pics! Do the Bolts have a lighted charge port available at all? And was there a tire inflator or anything else in the utility tray? What if you get a flat?
Yes, thanks for the share.............VERY nice :)
Discussion Starter · #50 ·
The charge port is not lighted. Mine did not have an air pump; I believe it has self-sealing tires.
41 - 51 of 51 Posts
