I've been meaning to post this for a while and keep forgetting... This past winter, I took the Volt on a trip where it stayed overnight in about -5F temperatures (battery fully discharged), and then I used it the next day to run some errands.
Not "super" cold, but the results were still telling. First, the Volt seemed to do its engine running when battery is too cold behavior, the point beyond "ERDTT" where the engine is essentially coupled to the wheels and bypassing any battery use. Eventually, that went away and the engine would stop when I was stopped. This mode has been fairly well documented here and elsewhere.
However, the other behavior I observed was that, for the majority of my driving during those errands, the battery did not want to take energy from regenerative braking. I could be going down a fairly long hill, after the above "too cold to use the battery" operation ended, in Drive, and the engine would turn off, but putting the Volt in Low would cause the engine to idle quite high and I don't believe any regenerative braking was taking place.
There were other small oddities as well, and because of the presumed lack of regenerative braking and more-than-normal engine idling, the MPG was actually pretty poor, I'd say considerably less than the 32mpg city rating.
I think it's an example where the Volt does not shine, but one that is typically not seen often if people plug in nightly as prescribed, which not only keeps the battery charged, but also keeps it conditioned from a temperature standpoint.
I'll try to remember to elaborate a bit more and also post a screen capture of the energy usage. It's in my camera somewhere...
