For those curious about real world results, here are some real world numbers and anomalies.
Did a 3,800 foot climb (all electric) in my 2013 Volt (No Ohms) over a 12.5 mile drive.(San Bernardino to Lake Arrowhead, California.)
I have it detailed for every 200 feet of elevation change.
Here are the numbers.
Started at 1400 feet above sea level with 7.9 miles driven from full charge. Miles remaining indicator (AER) 37 with 2.0 kWh used. It's interesting to see how much power is used in climbing, and how it affects the Miles Remaining Indicator.
Elevation---------Miles Driven---------Miles Remaining Indicator---------- kWh used
1400----------------07.9------------------------37--------------------------------2.0
1600----------------08.5------------------------33--------------------------------2.4
1800----------------09.0------------------------31--------------------------------2.8
2000----------------09.5------------------------28--------------------------------3.1
2200----------------10.2------------------------24--------------------------------3.6
2400----------------10.9------------------------22--------------------------------4.0
2600----------------11.4------------------------20--------------------------------4.4
2800----------------12.1------------------------18--------------------------------4.9
3000----------------12.8------------------------16--------------------------------5.3
3200----------------13.4------------------------14--------------------------------5.7
3400----------------14.0------------------------13--------------------------------6.1
3600----------------14.7------------------------11--------------------------------6.5
3800----------------15.6------------------------09--------------------------------7.0
4000----------------16.2------------------------08--------------------------------7.4
4200----------------16.9------------------------07--------------------------------7.9
4400----------------17.5------------------------05--------------------------------8.3
4600----------------18.0------------------------04--------------------------------8.7
4800----------------18.7------------------------03--------------------------------9.2
5000----------------19.3------------------------02--------------------------------9.6
5200----------------20.4------------------------00--------------------------------10.1
Of course, did not need Mountain Mode as I was doing very well on just electricity. The down hill run was interesting as well. This is where the anomalies crept in. Started the next day fully charged at the top of the mountain, then started down hill. I was wondering what was going to happen. At 4000 feet, Miles Remaining indicator maxed out at 60. Was curious to see the kWh to get back to zero. Was it going to read negative?? Strange things started happening after reaching 2900 feet. The display started reading gas miles used with no gas burned. Low wasn't as effective to slow the car down, and using the brakes only regenerated a little power (less than 1 kW back to the batteries for small amounts of time.) I suppose I should have turned on the heater, headlights, radio, powered the windows up and down, lock and unlock the doors, etc. to slow the car down....
Elevation----------Miles Driven-----------Miles Remaining Indicator----------kWh used
5200----------------08.3-----------------------38--------------------------------1.5
5000----------------09.1-----------------------42--------------------------------1.3
4800----------------09.5-----------------------45--------------------------------1.2
4600----------------10.1-----------------------49--------------------------------1.0
4400----------------10.5-----------------------52--------------------------------0.9
4200----------------11.2-----------------------58--------------------------------0.7
4000----------------12.0-----------------------60--------------------------------0.5
3800----------------12.5-----------------------60--------------------------------0.5
3600----------------13.3-----------------------60--------------------------------0.3
3400----------------13.9-----------------------60--------------------------------0.2
3100----------------14.6-----------------------60--------------------------------0.0
2900----------------14.7 electric 0.5 gas-----60--------------------------------0.0
2600----------------14.8 electric 1.3 gas-----60--------------------------------0.0
2500----------------14.9 electric 1.8 gas-----60--------------------------------0.0
1500----------------15.7 electric 3.8 gas-----60--------------------------------0.0
1200----------------17.1 electric 3.9 gas-----60--------------------------------0.2
AER finally reduces 26.8 electric 3.9 gas-----59-------------------------------2.0
Home---------------65.4 electric 3.9 gas-----05--------------------------------9.9
In retrospect, should have driven off the last remaining miles to see how far I could have gone. Could have possibly made close to 80 miles if I had been more careful, with 0.0 gallons burned, but 3.9 gas miles driven, even though they weren't actually gas miles. Having lots of fun with this Summit White Volt!
No Ohms
#1 Voltstats.net - Overall Category (299.99 points.)
#1 Voltstats.net - Most Electric Miles Driven in a Day (434.57)
