Like many of you, I've been on the quest to find a suitable replacement for the terrible stock headlights. I've been down the HID road (twice now) and still was never satisfied. HID's worked but the light pattern was always terrible and worse when cold I'd have startup issues or they would completely quit while driving. Bad enough when I'm in the car but unacceptable if it were to happen to my wife.
Enter the Morimoto 2Stroke LED kit.
I've been looking at this for a while and finally bit the bullet and bought a set. I got them from www.theretrofitsource.com in our 9012 style. Everything came nicely packaged in individual boxes.
One box with the lights and regulators, the other with the dustcaps and model specific adapters. There's also an envelope with a sticker, alcohol wipes and a quick install guide.
Here's what the light and regulator look like. Hello CREE XHP50!
This bulb is neat because the same unit will work with any headlight style with the use of an adapter that locks on that little nubbin at the base.
It's a big aluminum chunk with copper plates down the center and a fan on the side that blows past the copper plates to keep it cool. I tried to get a picture of it but couldn't, but the fan inside is a Sunon MagLev unit. Those are the more expensive and higher quality ones like I use in my computer cases. Nice touch there.
Here is one of the adapters with a very clear 9012 on the surface so they won't get mixed up if you have multiple types.
I started with the drivers side as there's a lot of room to work with. And once installed the bulb will look like this. The adapter just fits over the top and you give it a turn to lock it in place
Here I've pulled out my last crappy (read: cheap) set of HID's. I had previously drilled out the center of the dustcap and installed the rubber grommet with the wiring there.
As you can see, the center of the LED and HID are in the same spot so the light distribution should be about the same.
And here you have our lovely bulb housing. It's a simple push and turn to lock the bulb in.
..but it wouldn't go in.. I found the green gasket that comes on the 2Stroke bulb is too thick and I couldn't get it to seat in the housing. I popped off the red gasket from my old HID bulbs and put it on the 2Stroke. Popped right in. It may only be like this on the Volt, or even just my Volt, but wanted to point out I had to do that.
Now here is with the bulb and regulator installed. Note how much the bulb sticks out past where the dustcap should be..
Something I did for the old HID ballasts I did for the LED regulators too which was attach some industrial Velcro and attach them to the side of the engine bay so they're not dangling around.
And with it all Velcro'd up
Next I started working on the passenger side. It's..tighter..
So out came the airbox and lots of room is to be had! There's a metal bracket you can undo with a flathead screwdriver, then undo the mass airflow sensor clip and the whole thing just pops out. Might take a little wrestling but it'll eventually work free.
So now you have all this room to work with
Same as the other light, you'll need to swap the gasket for the thinner one and pop it in.
I did some Velcro for this side too.
It's really nice these lights also come with a set of extended dustcaps for the extra long bulb unit, but unfortunately the don't fit our large dustcover opening.. I guess I'll find some aftermarket ones later.
And now for the first test firing... And they work! First try!
And here's with the airbox back installed. It's a tight fit but it works. I don't think it will be possible to fit a dustcover on at least the passenger side at all. I'm not sure what the need really is anyway, the bulb housing itself it sealed by the bulb.
It was too bright to really do any testing so to burn some time I gave the Volt a much needed bath.
Here's what they looked like once I pulled in the garage
Here's the cutoff with the low-beam lights
And with high-beams
So the verdict? I love them so far. The light spread is very even and clean, no hot spots or dark spots. Road signs and street lines all illuminate brightly like they did with the HID's, it's really nice. I'll get more shots in the dark as time goes on and the real test will be interstate and long dark country roads.
I'll report more as I have it. I hope this helps someone else looking for LED options.
Goodnight everyone!
And with high-beams
Goodnight everyone!
