I've been doing some experimentation with MM Gaming the past 2wks to collect data on if I can truly improve my MPG and/or EV range (AER). Here are my results, I was able to improve both MPG and AER by an average of 25% over my baseline of using no MM. However, the standard deviation on the MPG is fairly high while the EV range improvement is rather predictable.
For each test, I attempted to minimize variables by maintaining consistent driving habits and use of climate controls. For climate I used Eco mode set to 75 and seat heater on 1 bar with occasional use of front/rear defogger as needed. For driving, my flat highway speeds were 65-70mph, and down to 50-55mph through the windy mountain pass. I drive in Normal L mode.
To understand my data, let me first explain my commute. I drive from south of Santa Cruz "over the hill" into San Jose/Santa Clara on SR 17 (one of the most dangerous highways in the state according to Wikipedia). Along this commute I traverse the Santa Cruz Mountains, climbing 1800ft to the summit before descending back down into the valley. The total distance is about 44.5 miles from home to work which breaks down as follows:
1) 0-1.5m Leaving my house is about 1.5 miles of cruising through the neighborhood at 25-30mph
2) 1.5-16.5m Then I'm on straight freeway (Hwy 1 and Hwy 17) at 65-70mph until I get to about 16.5 miles into the trip where the curves begin
3) 16.5-20.9m During the climb I'm at speeds of 50-55mph through the tight curves, at 20.9 miles I'm at the highest point of the summit and begin descending
4) 20.9-25.9m During the descent I get heavy regen braking, still travelling generally at 50-55mph, at 25.9m the sharp turns are over and I'm back to straight roads and higher speeds (traffic permitting)
5) 25.9-44.5 For the remainder of the trip I'm on flat freeway back to 65-70mph traffic permitting
Next I'll explain the 3 methods or strategy's I tested.
1) No_MM: First, my baseline or control is not using MM at all and drive in Normal L for the entire trip. I have 2 data points for this method.
2) MM_Incline: My second method was to turn on MM at or above 15 EV miles which tends to engage the ICE at about 16.5 miles into the trip, which just so happens to align perfectly with the start of the mountain climb! Then I disengage MM and return to Normal mode at the summit, 20.9 miles in. I regen all the way down and remain in Normal L for the duration of the trip. 3 data points for this method.
3) MM_Decline: My third method was to wait until I reach the summit OR was down to 4-5 miles of EV range (whichever came first) and then turn on MM and engage the ICE through the decent. Then turn off MM at about 26 miles into the trip at the base and back to Normal L for the remainder of the trip. 3 data points for this method.
UPDATE: Here's the elevation profile showing where the ICE turns on and off in MM_Incline and MM_Decline:
You can feel free to scrub my data for yourself, but here are my conclusions. First, both the 2nd and 3rd strategy showed significant improvements over the baseline of not using any MM. The 2nd method had the best overall performance with a 25% average improvement in both MPG and EV range, although the MPG stdev is rather high at 24.1. I'm planning to get a few more data points for methods 2 & 3 next week and see if the stdev tightens up. But for now I'll be sticking with method 2 as my default.
Summary data:
Method 1 Baseline No_MM (n=2)
135.8mpg +/- 11.7
31.0 AER +/- 1.5
70% electric
Method 2 MM_Incline (n=3)
169.7mpg +/- 24.1 (25% improvement)
38.6 AER +/- 1.5 (25% improvement)
87% electric
Method 3 MM_Decline (n=3)
150.9mpg +/- 46.8 (11% improvement)
36.3 AER +/- 2.4 (17% improvement)
82% electric
You can copy the data table below into Excel and perform a space delimited text to columns if you want to see the details or do your own analysis:
Strategy No_MM No_MM MM_Incline MM_Incline MM_Incline MM_Decline MM_Decline MM_Decline No_MM MM_Incline MM_Decline No_MM MM_Incline MM_Decline No_MM MM_Incline MM_Decline
Date 10-Jan 12-Jan 2-Jan 3-Jan 11-Jan 5-Jan 6-Jan 9-Jan
Start_Time 7:17 7:08 8:18 7:05 7:01 7:35 7:05 7:05
Stop_Time 8:44 8:15 9:05 8:55 8:05 8:33 7:56 8:22 Avg Avg Avg %Delta %Delta %Delta Stdev Stdev Stdev
Garage_Temp 51 51 54 51 54 54 50 46 51.0 53.0 50.0 0% 4% -2% 0.0 1.7 4.0
Low_Temp 41 41 49 41 37 42 38 38 41.0 42.3 39.3 0% 3% -4% 0.0 6.1 2.3
SOC 34 35 43 41 34 43 39 37 34.5 39.3 39.7 0% 14% 15% 0.7 4.7 3.1
MM_EV_Buffer_Miles N/A N/A 14 14 14 N/A N/A N/A 0.0
Peak_EV_Miles 2 3 8 10 9 5 4 4 2.5 9.0 4.3 0% 260% 73% 0.7 1.0 0.6
Base_EV_Miles 2 3 13 15 15 9 8 10 2.5 14.3 9.0 0% 473% 260% 0.7 1.2 1.0
MM_Start_(ICE_On) N/A N/A 16.8 16.7 16.2 20.9 20.4 20.3 16.6 20.5 0.3 0.3
MM_Stop_(ICE_Off) N/A N/A 20.9 20.9 20.9 26 26.2 25.6 20.9 25.9 0.0 0.3
CD->CS 29.9 32 42.1 44.4 43.3 44.3 40.1 41.1 31.0 43.3 41.8 0% 40% 35% 1.5 1.2 2.2
Trip_Distance 44.4 44.5 44.5 44.5 44.5 44.5 44.4 44.5 44.5 44.5 44.5 0% 0% 0% 0.1 0.0 0.1
Trip_Gallons_Used 0.3 0.3 0.2 0.2 0.2 0.2 0.3 0.3 0.3 0.2 0.3 0% -33% -11% 0.0 0.0 0.1
Leaf_Gallons_Used 0.36 0.33 0.26 0.23 0.26 0.23 0.36 0.36 0.3 0.25 0.32 0% -28% -8% 0.0 0.0 0.1
Trip_MPG 127.5 144 161.8 196.7 150.5 204.8 127 120.9 135.8 169.7 150.9 0% 25% 11% 11.7 24.1 46.8
Leaf_MPG 127 143 161 196 150 205 127 121 135.0 169.0 151.0 0% 25% 12% 11.3 24.0 46.9
EV_Miles 29.9 32 37.1 40.1 38.6 38.9 34.2 35.8 31.0 38.6 36.3 0% 25% 17% 1.5 1.5 2.4
ICE_Miles 14.5 12.5 7.4 4.4 5.9 5.6 10.2 8.7 13.5 5.9 8.2 0% -56% -40% 1.4 1.5 2.3
kWh 10.2 10.3 9.9 9.8 9.9 10.2 9.9 9.8 10.3 9.9 10.0 0% -4% -3% 0.1 0.1 0.2
Summary data:
135.8mpg +/- 11.7
31.0 AER +/- 1.5
70% electric
87% electric
82% electric
