Greetings,
So, I've been tinkering with the ELM327 and some custom software for a bit, and I decided I should try to calculate out how much power some of the things in the car actually use by watching the battery SOC precisely over time.
This is one of the things I've been interested in since I purchased the car so it would be possible to estimate how many miles per charge certain items "cost" in range.
This is using CAN ID 206 assuming a value of 0.25 Wh per unit. I calculated that the car uses about 375 watts while "idle" on average.
Here is a list I came up with, subtracting the idle usage of 375 watts from all values and rounding to the nearest 5 watts:
(Its interesting to note that the "Climate Power" percentage seems to have no real meaning...)
I also attempted tests for the radio, heated seats, and headlights, although these items seemed to have a negligible effect on the HV battery and I was not getting values outside of my idle power margin for error.
Now, lets assume you get 40 miles out of a charge which uses 10.5 kWh (which is about my average so far after 10,000 miles). This gives us a nice value of 262.5 Wh per mile for travel. Now, this is taking into account the idle usage of about 375 watts already.
Lets do some more estimating and say you'll be traveling at 55 MPH constantly for this charge. We'll just write off starting and stopping for sake of simplicity.
That gives you 43.64 minutes of EV driving. 272 Wh will be used by the idle components, the rest for momentum, 10.23 kWh. That's 256 Wh per mile for momentum.
Taking this further, lets say you were to run the rear defroster the entire trip @ 475 watts. for 43.64 minutes that would consume about 345 Wh, or approximately 1.35 miles of momentum.
Lets apply this logic to the list above and see what we come up with. I know the numbers aren't perfect because I'm assuming the additional load will be running in addition to the 40 miles for 43.64 minutes, but, it should be pretty close either way.
(Edit: This list has been updated based on the formula in this post.)
So, as you can see, different items certainly have an impact on EV range, some quite substantial. Especially that dang high voltage heater.
Now, granted, this assumes a constant "on" of these items, which isn't always the case, but, it should give a good idea one what uses the most juice.
I also did some readings for various methods of charging. These are pretty interesting.
As you can see, the ICE can dump a lot of power into the battery. I'm not sure what kind of impact these types of charge events have on the life of the battery, considering they charge it at over 5x the rate of a 240V 3.2kW charger, but, it is interesting. Theoretically, you should be able to have a dead HV battery, pop the hood, press the accelerator, and have a fully charged battery in 37 minutes. (I'd be afraid to know how much gasoline that would use, but, that's not the point...) This can't be good for the battery, but, proves that faster charging is, in theory, possible with the existing setup.
I also find it interesting that the owners manual says that the battery is neither charged nor discharged while the hood is open and the engine is running... this is obviously false.
I hope someone finds this information useful. I'll update as I tweak my software and get either more or more accurate readings for different things. Any suggestions on what to measure next and I'll do my best to try it.
-wk
EDIT: I'm sure this information would be more easily obtained with the DashDaq, however I don't own one.
Edit Log
- Rear Defrost - 475 watts
- Climate, Fan Only, Full (Climate Power: 17%) - 270 Watts
- A/C, Eco, LO, Auto (Climate Power: 34%) - 1,535 Watts
- A/C, Comfort, LO, Auto (Climate Power: 59%) - 1,875 Watts
- Front Defrost, 72F, Auto, Comfort - 1,425 Watts
- Heat, HI, Full Fan, Comfort (Climate Power 75%) - 6,250 Watts
- Sitting in D with foot on brake (0 MPH) - 0 Watts
- Creeping forward in L - 400 Watts
- Pedal to Floor in Sport Mode for a moment while stopped - 49,405 watts
- Rear Defrost - 475 watts - 0.95 miles miles (335 Wh)
- Climate, Fan Only, Full (Climate Power: 17%) - 270 Watts - 0.4 miles (190 Wh)
- A/C, Eco, LO, Auto (Climate Power: 34%) - 1,535 Watts - 3.55 miles (1,020 Wh)
- A/C, Comfort, LO, Auto (Climate Power: 59%) - 1,875 Watts - 4.3 miles (1,220 Wh)
- Front Defrost, 72F, Auto, Comfort - 1425 Watts - 3.29 miles (950 Wh)
- Heat, HI, Full Fan, Comfort (Climate Power 75%) - 6,250 Watts - 11.85 miles (3,200 Wh)
- Charging @ 240V - +2,990 Watts
- Mountain Mode Engaged while below threshold - +17,440 Watts
- Mountain Mode Engaged with accelerator depressed - +18,235 Watts
- Hood Popped, Idle - +6,850 Watts
- Hood Popped, accelerator depressed - +17,440 watts
-wk
Edit Log
- 07/10/2012 - Update list of range impacts with new formula.
