Anyone know what the max regeneration rate on a Gen 1 is? I see up to -40 on the kw meter but is all of that being absorbed by the battery or at some point is just dissipated?
I've seen the same.Max regen on the Gen 1 is 60kW. It is spec'd as such and I've seen it several times slowing down while coming off an interstate exit.
My understanding is MGA is the smaller motor, which is clutched to the engine in Range Extended mode to generate electricity "on the fly" as fuel for MGB, the primary traction motor.The max I ever observed on my Gen 1 2013 Volt was 59kW, while braking from 55mph. Theoretically, it should not be higher than 55kW (which is what MGA/generator is rated)
Would you consider going into Low at 70 mph / 110 km/h be a situation where one would expect to see maximum regen?The DIC number is the total high voltage power of the system - if it's positive, power is being pulled from the battery (or engine)
If it's negative, that amount of power is being fed into the battery.
When braking or L-coasting to a stop, the rate of regen is proportionate to speed/rate of deceleration. If you're not going fast enough, you might not see that max number.
If you are driving in single motor mode, you will see maximum 55kW regen from the single large motor (half the max output)
If you were in dual motor mode, you might see up to 60kW regen as both motors work together. This isn't as common as the system usually declutches fairly quickly. Typically 55kW is max.
Between this and other messages on this BBS, I am now convinced that my car has an issue, but I have no clue as to what it is. Therefore I have started a new thread so as to not hijack this one and filled the first post with as much information and I could think of.Shifting to L at that speed may get you there, but might be a bit below.
L+moderate to firm brake pressure certainly would.
But as you slow down, the regen rate will drop proportionately. So you'll only see 55/60kW max at the very start of the deceleration.
Thanks for this comment. It slipped my mind that when in two-motor mode, both motors are coupled to the drivetrain, and the car’s momentum could therefore use both to create braking regeneration. I would imagine the engineering would be remarkably complex. Surely it’s more efficient to use only a single powerful motor/generator to create regeneration, but that would require unclutching MGA from the powertrain in ev mode and from the engine and powertrain in power split mode. That process would introduce its own inefficiencies. And since regen often exists only for brief periods of time, subsequent demands for propulsion torque would require clutching the motor back into the drivetrain if the car’s speed and torque demands remained within the two-motor configuration parameters... whew!If you are driving in single motor mode, you will see maximum 55kW regen from the single large motor (half the max output)
