Had something interesting happen the other day. I was showing a friend the Volt (he has a Prius) and had the hood open. I turned on the car, which invokes maintenance mode, and of course the engine started. We could both hear the inverter singing. This appears to charge the main battery, even sitting still, in normal mode, and with the battery already over the MM engine cut-in threshold. We let it run for 15 min or so, and got another bar on the battery display, and more miles shown on the car (and of course, more gasoline usage).
After I got home, in MM I had the usual about 45% charge. I ran it some more in that mode and wound up with about 60% charge reported by the car itself. I didn't think to check MyVolt last night.
Trying it again this morning (cold out and I wanted some heat in the car) - same thing, more miles shown on battery display, more gas used - I shut it off after about 15 minutes and on closing the hood and restart, was showing about 70% charge - about another 10% from where the car reported before doing this. Curious about this, I came up here to the computer and checked with MyVolt.com - which showed not the number the car did, but the number it had when I parked it last night (44%) - the new charge didn't show up there at all. You therefore cannot use MyVolt (or presumably the smartphone apps) to monitor this at all, and I have no idea if now they will be out of sync permanently or will get back together if I drive the car, or fully charge it off home power.
This might be nice to know in an emergency for getting a full charge when there's no other way, or just to get the car warm of gas even if it's charged above where MM can kick in the gas engine. To me, that's relevant and potentially useful, as I'm fully off the grid and can't reasonably precondition the car early in the morning when my home system doesn't have the power to spare.
But one has to wonder - since there is a bug in reporting this to the outside world, could there also be a bug that would allow the battery to be ruined by overcharging it in this mode? Interesting hack at any rate.
