Check that all wheel nuts are properly tightened. See “Wheel Nut Torque” under Capacities and Specifications p.330
So it's the same as the Gen 1 (and most cars w/aluminum rims).on p.330
Wheel Nut Torque 140n.m or 100 lb ft
I found several references to it in the manual in the sections involving changing the wheels and tires. Page 328 in 2016 manual. Likely in a similar location in 2017. But it's the same as Gen 1 100 pound-feetANyone know the gen 2 recommended torque for lug nuts? Can't find it in the manual.
Caution
Improperly tightened wheel nuts can lead to brake pulsation and rotor damage. To avoid expensive brake repairs, evenly tighten the wheel nuts in the proper sequence and to the proper torque specification. See Capacities and Specifications
0 328 for the wheel nut torque specification.
Page 330 in the 2016 manual. 100 lb ftANyone know the gen 2 recommended torque for lug nuts? Can't find it in the manual.
Yeah didn't check in the specs section. Other cars have it listed in the wheel tire section.At least the OP tried looking in the owner's manualI like using the PDF version. Very easy to search.
Heck, I trust no one to torque it correctly. But yes, at least verify. They all love the impact wrenches and I have found over-torquing in more than one case. Tire shops or dealers, it depends on the person doing the work.Yeah didn't check in the specs section. Other cars have it listed in the wheel tire section.
FYI, I have a torque wrench. After an incident 2 years ago with a GM dealer, I don't trust them anymore and check afterwards.
Quoting for truth. Was trying to figure out how to do the all-window roll down thing to impress a coworker, but couldn't figure out how (thought it was a lock followed by a double tap of the remote start, WRONG). Searching the PDF manual on my phone surprised my coworker who never thought to keep the manual on their phone. I do this with almost all major appliances so when I need to lookup a part while at Home Depot or something, I know the appliance model number.At least the OP tried looking in the owner's manualI like using the PDF version. Very easy to search.
Press and hold unlock.Quoting for truth. Was trying to figure out how to do the all-window roll down thing to impress a coworker, but couldn't figure out how (thought it was a lock followed by a double tap of the remote start, WRONG). Searching the PDF manual on my phone surprised my coworker who never thought to keep the manual on their phone. I do this with almost all major appliances so when I need to lookup a part while at Home Depot or something, I know the appliance model number.
Another option is to get a used CTS wrench (i know it's the right size for the G1, not sure about g2). I found that GM made the wrench just long enough that when you cannot tighten any more, it is about the right torque. I've checked it with a torque wrench and it works.So it's the same as the Gen 1 (and most cars w/aluminum rims).
And as always I STRONGLY recommend using an actual 1/2" torque wrench (and a deep dish socket) for any Aluminum rims, don't "guess-by-feel" because the price you'd pay for a mistake is a lot more than the $40ish for a decent wrench.
Yep, my 2012 Cruze Jack Kit wrench fits my Gen 1 Volt lug nuts perfectly.Another option is to get a used CTS wrench (i know it's the right size for the G1, not sure about g2). I found that GM made the wrench just long enough that when you cannot tighten any more, it is about the right torque. I've checked it with a torque wrench and it works.
I too hate placed that impact wrench everything. Every time I have warped brake rotors, it can be linked to someone messing with my wheels with an impact wrench. That's why I avoid letting the dealerships and tire shops rotate my tires. In fact I stopped rotating my tires altogether.
Huh, didn't know this was caused by over-torquing. TIL, I was shafted possibly by oil change shops on my old ICE when I had my rotors refinished TWICE over 10 years--the lube shops probably over-torqued my wheels during their "complementary" tire rotation.I too hate places that impact wrench everything. Every time I have warped brake rotors, it can be linked to someone messing with my wheels with an impact wrench. That's why I avoid letting the dealerships and tire shops rotate my tires. In fact I stopped rotating my tires altogether.
Yes, Many vehicles (especially Jeeps, believe me I know this fact well) are famous for warped rotors from over torqued lug nuts, or ones torqued in a circle, not a star pattern.Huh, didn't know this was caused by over-torquing. TIL, I was shafted possibly by oil change shops on my old ICE when I had my rotors refinished TWICE over 10 years--the lube shops probably over-torqued my wheels during their "complementary" tire rotation.
Never, ever lubricate the lug nut bolt or nut threads. This will lead to over-torquing and there is no need for it. I rotate my own wheels every 7500 miles and have never had an issue removing the lug nuts. If you try to under-torque, you basically are guessing.The eternal question lubricate threads or not ?
I have had the aluminum wheels seize to the steel hubs due to galvanic action, but never the lug nuts. So use the anti-seize (very lightly) where the back of the wheel mates to the steel hub, but not the lug nuts.
