1 - 20 of 20 Posts
While reading another poster's issue with a broken EVSE adapter that occurred after being stuck in the charge port, it got me to thinking how my adapter occasionally is difficult to pull out of the charge port. While I haven't paid much attention, I imagine it may have something to do with humidity however temperature does not seem to be related as I have noticed issues both during winter and summer. Does anyone use any type of lubricant or have other tips to allow the adapter to more easily slide into and out of the charge port?
You could check into dielectric grease. At least that is what my husband THOUGHT might work. He wasn't for certain on that, so definitely check the manufacturer or some other expert. FWIW
(Hubby is an ASE master tecnician who is full-time faculty in the local college program. They do have a Ford Focus in their program and he is very knowledgable, but not an expert in this area.)
I have not applied anything to mine. I don't want a sticky, dirty mess.
If you feel the fit is a bit tight, try using some 400 grit wet & dry sandpaper on the outer plastic sleeve on the charge handle. Use water, you are basically smoothing and sanding it down a bit, but I really don't think it's needed. They will slowly wear a tiny bit with use over time.
I think the main thing to do is to periodically check for debris in both the plug and receptacle. Lube certainly probably wouldn't hurt but just making sure the contact surfaces, both plastic and metal pins are free of anything that might cause the connection to jam up. Perhaps an occasional squirt with some compressed air to blow out any dust/dirt that may have accumulated would be good practice. I personally have not used anything on my port or plug and although the fit is a little tighter with my L2 plug, the original 120V plug does appear to be a slightly looser fit which I've just attributed to the plug being a little more worn than the L2.
My CC LCS-25 is 5 years old and still operating as designed having serviced three Volt's, two simultaneously for 18 months. But if I started experiencing any issues with how it performs and needed some technical support, I'd call them. I'm not going to try and fix something like this without first talking to the manufacture.
When my OEM EVSE got stuck on my 2012 Volt, it was because of a joint inside the handle and was not serviceable without breaking the handle apart, which I had to do to get it off the car. Luckily at the time it was still within the 3 year bumper to bumper warranty and the dealer replaced it, but I imagine that I could have lubed the joints and siliconed the handle back together if it wasn't covered under warranty. I have a 240V EVSE now, so I haven't used the OEM one in several years.
I assume we are talking about the plastic/fiberglass plug itself and not the contacts... so I don't know if you want to put dielectric grease on that. Mine was a bit difficult to get on/off so I sprayed a little WD-40 on a paper towel and just "cleaned" the surfaces of the connector (male and female side) with that. It didn't leave any residue or greasy film but it made it just slippery enough to slide in and out easier.
Mike
Super Moderator
My gen-1 EVSE was an absolute bear to plug in, tight to the point the plastic would creak.
I finally found a small ridge that I sanded down w/400 grit and then wiped the plastic w/a silicone cloth and it was much better after that.
I also spray it all out (car and EVSE) with contact cleaner and compressed air about once a year.
All this talk about lubing your parts, and no Elemental to knock a zinger out of the park.
Senior Member
I use NOALOX on the pins of the evse and port. My juice box was tight enough at first it was leaving copper shavings when unplugging.
Never needed to reapply it. Buttery smooth now.
Silicon lube works well... Jut spray a touch in...
New here.
After reading this particular thread, I realized my plug was also a little difficult when unplugging from the car, I have an OEM Voltec L2 charger. I used some leftover oil from an a/c compressor on the outside.
That helped some but I found out that the majority of the friction was being caused by the inside of the outer ring in the handle. I used silicone grease and q-tips to apply it everywhere I could reach on both the car side as well as plug handle, but obviously, NOT on the metal contacts.
Now it is smooth as silk.
Spray silicone lube. I used it once, 4 years ago and that's all it took.
1 - 20 of 20 Posts
