Hello,
Does anyone know who makes lowering spring or coilovers for the Bolt EV?
A seriously bad idea, the Bolts battery is on the bottom of the car, putting it close to road hazards will likely end up with a punctured battery and the repair cost will be all on youHello,
He's not talking about slamming the car to the ground. A mild lowering like 1inch would not do any harm. It would look much better imo. Lots of people with Volt lowered and I don't hear any batteries exploding. The bolt has a thick steel bottom plate. If someone has a big enough impact, the car will be totalled way before putting damage to the battery so its really not an issue. I've had lots of lowered cars and never had any problems. You just have to use common sense.A seriously bad idea, the Bolts battery is on the bottom of the car, putting it close to road hazards will likely end up with a punctured battery and the repair cost will be all on you
