1 - 3 of 3 Posts
One of the better threads on bumper fascia removal with photos:
https://gm-volt.com/forum/showthread.php?182386-Projector-retrofit-completed
Once you have it off, release the grille tabs from the front bumper lower fascia center grille to get it out.
With that out of the way, carefully push a small nylon wedge between the upper fascia and the lower fascia. Insert a small flat-bladed tool into the fascia slot and depress the tabs one at a time and pull on the upper fascia at the same time to gradually remove the lower fascia from the upper fascia.
1 - 3 of 3 Posts
