Has anyone tried to implement a "long range" mode? I've read some threads on this but couldn't find something that fits the exact question.
People have used MM to do something similar. My thought was to figure out a way to reset the hold mode set point. I've tried it on a few trips and seem to get a 10-15 MPG increase. Recharging the battery with the gas engine reduces the MPG's. The idea would be to simply reset the hold mode set point so it doesn't use any (or very little) gas to recharge the battery. I've been doing this by being in hold mode, then switch back to normal for a few seconds and then back to hold.
It seems to work best for drives that are more than 80 miles. Of course, once the EV range is exhausted, this will no longer work.
Is the mode button on the CAN network? If so, does anyone have the ID? If the reporting isn't very quick, seems like it can be done. It would be perfect if the hold mode set point was a CAN variable. That's exactly what I'd need.
The only thing I haven't had time to figure out is if the switching back and forth reduces efficiency so much that it's not worth it. That's something that can be tested over a few more drives.
