Glad to be able to hear the rest of the story, thanks for coming back with the conclusions.
Good to hear the dealer treat you right. Is your Volt operating 100% at this time?CONCLUSION TO THIS STORY...
After many hours at the Chevy dealership, here's the highlights
- The strange error code I was getting was due to me putting a fuse back in the wrong spot. ooops...
- The charging receptacle (the piece that mates with the EVSE plug/cable) was damaged. It was definitely cracked. I suspect this was a growing problem the lightning may have made worst. Not sure. This was replaced but did not fix the problem. Note the Volt Tech reported this component being cracked is a common repair.
- Next the battery charging module was replaced (the piece up front right under the bumper). This also did not fix the problem. Whether it was broken or not can't be known with certainty.
The HPCM2 was replaced. I'm not super sure but this is the brain and AI that calculates your range and stuff. This was replaced and the car is now fixed!
- My Level 1 EVSE that came with my Volt is destroyed. The two smaller pins on the side are supposed to read 1V put read like 0.1 V. So the lightning wiped this, which is surprising as it was plugged in, but was not plugged into my car.
All items except the EVSE were covered by the Voltec warranty. It was $1,700 worth in parts alone. Ouch...
Ditto......if we're having thunder storms, I unplug.I unplug during lightning storms. Less than a year into my 2013 Volt when I bought it new same thing happened. Lightning strike/surge. Had the onboard charger replaced.
This is a really good question. I assume it would be covered less your deductible up to whatever dollar amount is specified in your policy for this type of damage.this got me thinking, If we didn't have the Voltec Warranty and this happened, Would it be covered by home owners insurance like our other electronics, fridge, stove, microwave, computers, etc?
I would not be concerned, 87F is not too warm. In my garage on a hot day my garage reaches ~ 98F. When my Volt is parked inside my garage it takes 7 - 8 hours for the Volt's battery temperature to rise to where the fan and AC briefly come on to cool the battery pack. It takes a long time for the ambient air temperature to heat up a 500 lb battery pack.Have a quick storm about to blow through right now. Trying to figure out what's worse:
1. Leave car unplugged in an 87 degree garage
2. Plug car in and get hit by lightning.
My solution is to sit in car with it unplugged but on with the garage door open until the storm comes. Quite comfortable!
Thank you! It was 94 degrees outside when I pulled into the garage this afternoon and started charging. This was the first time I noticed the fans coming on while charging.I would not be concerned, 87F is not too warm. In my garage on a hot day my garage reaches ~ 98F. When my Volt is parked inside my garage it takes 7 - 8 hours for the Volt's battery temperature to rise to where the fan and AC briefly come on to cool the battery pack. It takes a long time for the ambient air temperature to heat up a 500 lb battery pack.
I would wait to charge until after the storm passes.
