I wasn't immediately impressed by the lamps you're considering.
Like you, I prefer the LED option, although I've had to add aftermarket spotlights to get the high beam range for my satisfaction.
LEDs are often lacking in the range department.
The example you put forward seems to lack specifications in the wattage output / used, and 1750 lumens is not a huge amount more than standard.
Lumens are a standard mostly misunderstood, and misquoted, so don't be too closely guided by them.
The heat sinking tabs might be difficult to work with in the reduced space behind the globe.
3 emitters per side is not lots, so unless they are very high quality with a top brand behind them, they probably won't be good.
After reading your item more carefully, I am somewhat appeased, so it is up to you. This is my opinion, and I'm near the fence now.
I looked long and hard for 18 months before I found a LED emitter with reasonable output characteristics.
I didn't compromise on lumens, but did compromise on them having their own fans, and I can hear them when I'm driving at low speed.
My surprise at them only costing $50AU was bonus.
http://gm-volt.com/forum/showthread...ade-Volt-HIR2-9012-HELP&p=4277241#post4277241
They are well made, it would seem, as they look robust, and have worked perfectly for 6 months, (I use them more than many others might)
Their downside is that they have a dark spot right where there's meant to be a hot spot.
So I can't reasonably recommend these either, but I think they're a lot better than the ones you are looking at.
I promise to take some pics soon. I'm off to get my Volt serviced for the 4th time in a few hours.
Prolly will have an opportunity for some images then.
