I have a line (older wiring) running to my garage that I believe is 110 Volt...would I be able to use a level 2 charger and charge at 16 Amps with this line or would I have to run a dedicated heavier gauge wire for 240 volt? I'm not familiar with wiring and amp/volts but I know it would be a bit pricey for an electrician to run over 60' of new wire with conduit from my electrical box to my detached garage along with the outlet and breaker switch...I could save some money with the line that's already in my garage but I'd like to charge at 16 amps instead of 8 amps or 12 amps. I attached a pic of the exposed wiring that goes into a switch (#1) and then into a box (#2).
