I'm sorry if this has been asked before but I'm a bit confused. I have a 2018 Volt Premier and I'm looking to install level 2 charging at my house. I have a couple of questions because I read that I should have a 40amp breaker in the panel and I thought I could use a 30amp for the Volt. I'm also interested in being prepared for the future as much as possible without having to run a new line.
(1) Can I get away with this? Install a 30amp breaker in the panel with a 30amp line run to garage into a 240v 30amp outlet?
(2)Am I better off running 40amp or 50amp line from the breaker to the garage with the 30amp breaker and outlet (or do I need a 40amp breaker and outlet?)?
I have gotten some quotes and the higher amp line run is obviously more expensive so wondering your thoughts if I want to keep cost reasonable but also future proof. One of the electricians mentioned that he believes the amp ratings will come down in the future anyway, is this true?
Thanks for your help for a new and slightly confused Volt owner!
