Enterprising !!!... my level one charger failed on me last week ... it is acceptable to swap chargers with a Volt or Bolt owner and have them claim the nonfunctioning charger under an active B2B 36K mile warranty.
is there anyone .... warranty my broken one for me. ... it would mean a lot to me if you could help.
Really? GM told you that? I find that hard to believe...GM has informed me that because this part is not VIN specific, it is acceptable to swap chargers with a Volt or Bolt owner and have them claim the nonfunctioning charger under an active B2B 36K mile warranty.
Some older EVSE were replaced, at GM's expense, under the Voltec warranty by mistake. GM has since clarified that the OE EVSE is only covered by the 36/36 BTB warranty. Further confusing the EVSE warranty issue is that the original Gen 1 EVSE, manufactured by Lear, the one with the orange power cord were replaced under a manufacturer's recall notice as the Lear EVSE would overheat.I'm not certain but I thought the charger is covered by the the electric propulsion warranty, check your owners manual.
As in my original post, I specifically was told it was not VIN specific (added a comma), then it was suggested to me as a loophole by the customer service rep I spoke with, then I called the parts department at my local dealer to confirm. So, I figured that it was a moral grey area at best as there are no rules against it, but I'll back off of the idea of seeing as you guys aren't fond of it.Really? GM told you that? I find that hard to believe...
If the box is showing green, then it sounds like the problem is from the box to your car?!? Why don't you install a 240v outlet and get the $210 AmazingE level 2 EVSE. It's dirt cheap and it has Clipper Creek components.As in my original post, I specifically was told it was not VIN specific (added a comma), then it was suggested to me as a loophole by the customer service rep I spoke with, then I called the parts department at my local dealer to confirm. So, I figured that it was a moral grey area at best as there are no rules against it, but I'll back off of the idea of seeing as you guys aren't fond of it.
Everyone, thanks for the great Ideas regarding alternative EVSE options, I am looking at the duosida unit currently, and possibly having clipper creek repair my defective unit. I think the line that runs from the box to the plug has been damaged or severed internally from constant movement. The box shows green when I plug it in.
