1 - 15 of 15 Posts
Searched and searched. Cannot seem to find the correct part number for 2014 ELR 5-button keyfob replacement. One of mine went through a Maytag heavy cycle and is toast.
Thanks. All I was getting was the wrong one for CTS/SRX.
And yeah, I realize it ain't cheap.
· Senior Member
Open it up, pull the board out and take an old toothbrush and scrub it down with some rubbing alcohol and let it dry out a day or two. Pop in a new battery and it will probably work...
Mines been through the wash a lot of times :/
The part number is unique to the ELR, but I would imagine something else would program to the car. You could always pick up a cheap one on eBay and give it a shot.
· Senior Member
Well I tired pairing a loaner CTS-V key I had when the ELR was in for service and I picked up/dropped after hours for funsies and it didn't work. I assume they are different frequencies.
I picked up an ELR with only one key. Has anyone been able to add a new key with the procedures in the owner's manual using an existing key fob? The instructions is turning the key counter-clock 5 times after opening the trunk to enable the add key menu. Turning it counter-clock is not possible due to open button on the trunk trim. I also took out the silver trim to find out the lock only turns in 1 direction, clock-wise.
The directions to added another key appear to be the same across all Caddy models around the same years. The key part being turning the physical key counter-clock.
The see the alternate instructions for adding another key without an existing key. Takes a little longer but still require turning it counter-clock.
I went to the dealer to have my FOB programmed.It's nice to have a friend work there,,programming via gm link was in the order of 20mins.kinda a pita,,gm wants to make sure your not a car thief.
out of curiosity,I tried to put my key in the trunk lock and it won't turn CCW,,license plate light is in the way..guess I choose correctly in having my friend program my extra key.
btw,,anyone else notice these keys don't like the cold?
1 - 15 of 15 Posts
