1 - 5 of 5 Posts
Have 2017 Volt. Have 1 original key and 1 un-programmed ebay bought key. Is it possible to use 1 original key to program the other key? I've read all the posts, and responses are confusing as to the conditions need to program 1 key using 1 good known original key.
From the manual:
If a
transmitter is lost or stolen, a
replacement can be purchased and
programmed through your dealer.
A new transmitter can be
programmed to the vehicle when
there are two recognized
transmitters.
You can program new transmitters if you have both of them. Otherwise you need to go to the dealer.
2014 Cadillac ELR
If you have a GOOD high end scanner, a second transmitter can be paired without a dealer visit. I just used our SnapOn Solus to pair a second one. I know most people don't own a scanner like that, but most local garages do. If they can do it, it will cost less than the dealer.
From the manual:
If a
transmitters.
You don't have to go to the dealer. You have to reprogram the new and the old fob. Be patient the reset process takes 10 minutes between each step and the display will notify you each time you need to press the start button for 2 seconds to start the next step. Once your new and old fobs are programed be sure to hold the start button for 12 seconds the exit programing or the fob will unlock and lock the car but not start it. Also I was able to go to my local Ace hardware to have the sidewinder key cut for the new fob.
1 - 5 of 5 Posts
