And to add more questions: Did you put the plug on yourself or did your electrician do that? The LCS-25 is technically a hardwire install, correct?So this particular clipper creek charger is a "plug-in" type vs hard wire? .....because that's exactly what I want...240v portability!
Ours arrived Friday. I slapped a plug on the end that matched our dryer [which sits beside the door to the garage] and manually swap the two as needed for now. Having a plug installed in the garage ASAP.The unit comes with bare wires, to be hard-wired. However, it's not a big deal at all to buy the correct plug and receptacle and make it a plug-in setup. I showed my electrician and he said it's very easy if you're somewhat knowledgeable about electrical stuff.
This is definitely what I would recommend. With this setup you can plug into any standard clothes dryer outlet. When you are visiting friends/relatives, if their clothes dryer is near the garage, you would be good to go.The unit comes with bare wires, to be hard-wired. However, it's not a big deal at all to buy the correct plug and receptacle and make it a plug-in setup. I showed my electrician and he said it's very easy if you're somewhat knowledgeable about electrical stuff.
