Hi. I have a few questions. My boyfriend has a Tesla 3 and can charge in our garage in a 220 outlet he had installed. We also have a 110 outlet on the outside wall of our garage that we used to charge our 2015 Prius. (Sold yesterday).
Do we need to buy an adapter for the cord that we use to charge the Tesla, in order to use it on the new Volt? If so, where do you suggest we buy it and what is it called? It would be nice to charge the volt at a faster rate.
If we go to the mall and want to charge the VOLT while shopping, do I need to bring my charge cord I received with the volt or will the cord on the charge port be sufficient?
There are many different types of 220 outlets depending on the application and maximum amperage rating. If your BF's Tesla Mobile Connector is plugged into the 220V outlet it is not recommended to repeatedly plug and unplug as these outlets are not designed for that type of service (think plugging in an electric oven and leaving it plugged in for years.)
That leaves the 110 outlet; it can be either a 15 amp or a 20 amp circuit. The Volt will charge using the 110 outlet using the charging cable (properly called electrical vehicle service equipment (EVSE)) that came with the Volt at either 8 amps (default) or 12 amps. For the 15 amp circuit you should only select the 12 amp setting if there are no other devices on the same circuit otherwise this will overload the circuit and trip the circuit breaker. Check the main electrical panel and figure out if the 110 outlet by the garage is on 15 or 20 amp breaker; you will more likely to not trip the breaker if this is a 20 amp circuit. The difference is that the Volt will only charge at 2.7 miles per hour using 110 and 8 amps but will charge at 4 miles per hour if you can use 110 and 12 amps setting.
If you were to purchase an EVSE designed for 220 you could charge the Volt at 12 miles per hour using 220 and 16 amps but that would require a separate 220 circuit since as previously noted you don't want to be continuously plugging/unplugging from the 220V outlet.
You could purchase a Level 2 EVSE for the Volt that would plug into the 220V outlet and then the Tesla could be charged using the 220 EVSE used for the Volt when the Volt was not being charged by using the Tesla Charging Adapter (see photo in earlier post) but only one vehicle could be charged at a time.)
If there is physically room in the electrical panel and there is adequate additional electrical capacity available you could add a second 220 outlet for the Volt (it only needs to be a 20 amp circuit.)
