Just wanted to share some pictures of my JuiceBox Pro 40 installation. Some of you may have seen my earlier thread when I was searching for a solution for my particular parking situation. Basically I needed something that could be securely mounted in a covered, shared, outdoor parking area and also wanted a way to track my electricity usage so I can pay back my homeowner's association since the circuit would be coming off of a main shared panel and not my own personal electric meter. I also wanted a way to lock the handle to the station if possible to deter other people from using the unit while I'm not around (since I'm paying for the electricity).
The JuiceBox Pro 40 ended up being my pick because it offered a locking bracket, the hole in the charge handle to insert a lock so it can be locked to the car or to the holster, wifi for internet connectivity and usage tracking, and was available as a plug-in version so I can easily remove everything myself when I move and just leave an outlet behind. I went for the 40 amp unit just so I'm ready for the future when I may get an all electric that can support more than 3.3 kW charging.
I had an electrician wire a 50 amp circuit and run the wiring through about 60 feet of metal conduit that they mounted along the wall leading to my parking spot. They installed a 14-50 outdoor outlet with a large "bubble" cover. I also went ahead and paid to have them put a true kWh meter on the circuit right as it leaves the breaker box so I can easily note the usage from month to month and so my HOA can verify that I'm reporting the correct usage if they ever feel like it (the meter is continuous and can't be reset).
I mounted the JuiceBox unit right above the outlet and the holster/cable hanger to the side. You can see the nice padlock I am using to secure the locking bracket on the left side of the bracket. I then used some zip ties to tidy up the hanging power supply cord and secure it to the metal conduit. There's also a slot for a small lock on the bubble cover. I used another zip tie to secure the cover shut so it can't be easily unplugged but didn't want to use a lock in case there was some emergency need to unplug the unit (can always just snip the zip tie).
The JuiceBox and locking bracket were $624 from EMotorWerks and I paid the electrician $550 for the install including running the 60 feet of metal conduit, buying and installing the 50 amp breaker, buying and installing the kWh meter, and setting up the outlet and outdoor cover. He also went ahead and mounted the JuiceBox and the holster to the wall for me while he was here too. Total cost around $1200 with the padlock of which I expect $360 back at tax time so about $840 net.
It's super nice to not have to deal with the portable charger and also have the car totally recharged in only 4 hours versus 12+ now.
