OK, just to get this out of the way - Auto Defog is turned OFF. Besides that, it's currently clear and very low humidity.
What's happening is that no matter how warm we set the desired temperature in our 2014 Volt, the Air Conditioning Indicator on the Climate Screen will almost always go to "ON" when ECO or Comfort is selected. When doing this, the air blows cold. Very cold - I believe the AC is on. Sometimes if I'm messing with temperature or turning on Defrost, both the the Air Conditioning Indicator AND the Heat Status Indicator will go to "ON" - but only momentarily. Then it will revert back to AC only.
Something that is probably related - the Outside Air Temperature Display seems to always be displaying 38 degrees, even in our garage that is probably in the mid 50s. That alone shouldn't make it always go to AC, however. I'm suspecting that both the outside and cabin temperature readings are messed up somehow, and confusing the system. Is there a common point of failure that could do this?
Any suggestions or insights? We'll probably take it to the dealer, but I've always found things go better if we already know the root cause.
Thanks,
Mike
Thanks,
Mike
