1 - 8 of 8 Posts
The button did not work intermittently. It required to press harder to open the door lock. Now it stopped working at all. Buttons on 3 other doors are working fine. Also I can lock/unlock the car using remote.
Does anyone has similar issue?
· Administrator
You know your new car has a warranty, yes? With all the issues you are reporting, take it in to the dealer service department for repair.
This seems to be coming in droves today...Q: XXX is broken, what do I do? A: Take it to the dealership for a bumper to bumper warranty fix, duh!
Definitely, sooner or later I will take it to the dealer. I wanted to know whether anyone had similar issue.
I've got the same issue. Still works though. During cold and wet weather, it would work probably 50% of the time, in other words, I had to press twice to get it to unlock. In warm and dry weather, it works about 80% of the time.
My oil change is coming up, so I get the dealer to fix it when I bring it in.
Same thing starting to happen to the driver's door on my 2017 I bought in March 2016. Sometimes doesn't unlock unless I press it multiple times. It seems as if I pull out the door handle and then try it, it will work more repeatably, but that could be a coincidence.
So far the only problem I've had with my 2013 CPO Volt was just as described above. The driver's door lock/unlock features were operating erratically using the switch in the handle. After a few months it went out completely. The dealer replaced the driver's door handle as the switch is not separable from the outside handle. That fixed the problem and it was covered under my 12/12 CPO warranty.
1 - 8 of 8 Posts
