I bought the Volt 3 mos ago - great car! Electric range before ICE start of 44 - 49 miles, but winter is coming. Still getting used to the handling, as it seems a bit tail heavy on tight corners compared to previous gas FWD. Does anyone know the weight distribution?
I ran a few errands yesterday - no commute, the beauty of retirement! - 13 miles, 2.9KW used, 33 miles estimated remaining. I pulled the car into the garage and turned it off normally, but did not plug it in. Garage is not heated, but was probably about 55 degrees.
Last evening I had to go into the garage and noted a low "whirring" sort of sound. It appeared to be coming from the car, but I couldn't really localize it. I looked in the driver's window to make sure it was off - the center stack was dark, but it looked like the backlight was on in the driver's display. I got a remote, turned the car on, waited a couple of minutes and turned it off, then exited and waited for all the interior lights to shut down. The noise continued and the display still looked backlit.
I left it and this morning it was back to normal - no noise, no backlight, no change in the energy stats.
Was this the battery heating system running? I plan to keep it plugged in when it gets colder, but it surely doesn't have to be plugged in at 50 - 55 degrees?
