Is that a 12V Battery?
7970 Views 3 Replies 3 Participants Last post by  Ladogaboy
Does the Spark EV have a 12V battery up front?
1 - 4 of 4 Posts
Sure has the general shape of one. Has to go somewhere...
I have read no direct information about the Spark EV systems. But I believe that GM will use the same startup systems as in the Volt. The 12 VDC lead-acid battery is the main power for the control electronics and uses that DC power to startup and activate the larger lithium-ion traction battery. Then there is a DC to DC converter to keep the 12 VDC battery charged from the traction battery.
Maybe in the future the 12 VDC battery could be a smaller and lighter lithium-ion version to save weight.
Yeah, the 12V is a typical setup for EVs, but I wanted to confirm. 12V lead acid batteries will probably be used for some time, because they are still more durable than lithium batteries.
1 - 4 of 4 Posts
