hello, I recently took a longer trip than my usual <20 mile commute which gave me the chance to use the hold mode. the trip was about 85 miles each way, so my plan was to split the miles evenly between full electric and hold mode. however, my electric range would drop sharply on inclined roads. I would lose about 2 miles of range when driving for no more than a mile. so to preserve the electric range as much as possible, I would switch to hold mode when the electric usage would go above 20kw, and would switch back to normal mode when below this number. my logic was that the car ran more efficiently on gas when a little more power was required. I have no idea if this is true or not
. when the electric usage rose above 20kw and remained there for some time, I switched to hold, and when the road flattened a bit, I would switch back to normal. I did this throughout the entire trip. I'm not sure if this is the correct/efficient way of using hold mode? would it be best to stay in hold mode until the remaining distance of the trip equals the electric range? or is switching back and forth a good idea?
some pictures of the end result:
