Yesterday I sat my my 2012 Volt parked and turned the ignition to the "ACC" position (by holding the power button for 5-6 seconds without stepping on the brakes) so I could run my AC inverter to charge and play on my laptop while I waited for my wife. I also have the Torque App and monitor many parameters from the car, one of them being the 12V battery voltage.
I don't remember what the 12V battery was when I parked, but it was after a 30 minute drive (and this car is a daily driver) so I assume the 12V battery was fully charged, but after 30 minutes using and charging my laptop with the ignition on ACC, my 12V battery had fallen down to 12.1V and my AC inverter stopped working.
Nothing in the car was on except for the radio at a low volume and my laptop charger (which I assume was drawing 5-6A from the 12V accessory port).
I just read that the car has a 40A/hr battery, which should've gone a lot longer than 30 minutes before reaching 12.1V (which I figure to be 30-50% discharge on a lead acid battery according to this https://i.stack.imgur.com/B2gEX.jpg and many other graphs I found).
So should I replace it or am I wrong about some assumption I made?
