Link says it all: http://pushevs.com/2017/12/09/auto-bild-tested-range-8-electric-cars/
Imagine Ioniq's range with 60kWh batteries....
The crossover between static loads and aero loads where the vehicle has the least energy required occurs somewhere around 20 mph for a modern car without big HVAC loads. EV efficiency is sufficiently even that this is likely the longest range speed to drive at, too.What is the sweet spot for highway speed that does not kill range? Do you also know CD for volt gen1?
Cd for the Gen 1 Volt is 0.28. I have found the "sweet spot" for the Volt (unless you are trying to hyper-mile) is in the 40-50 mph range. Aero drag force varies with the square of the speed and power varies with the cube, so going from 50 mph to 70 mph doubles the drag force and the drag power almost triples. 80 mph is an absolute range killer.
FYI, 0.28 is an excellent drag coefficient and the Bolt's 0.31 Cd also is very good, compared to almost any ICE vehicle. For example, the sporty and sleek Mazda RX-7 has a 0.31 Cd. Tesla gets all the rave with the 0.23-0.24 Cd range, but it isn't that much of a factor in annual overall driving range, as Cd really only makes a difference at highway speeds. Most daily driving for most drivers, except for long-distance commuters, is 50 mph or less.
Also note the the Cd is only one-half of the equation of body geometry affecting drag. The other half is the frontal area ":A". Total drag factor is Cd x A, expressed in square feet or square meters. Frontal area for more roomy vehicles with more head room will necessarily be larger.
https://en.wikipedia.org/wiki/Automobile_drag_coefficient
Ari will probably disagree with your sweet spot. And unless you can post 80+ miles in a Gen 1 car, I'm gonna believe his number of 23-24 MPH being the sweet spot.Cd for the Gen 1 Volt is 0.28. I have found the "sweet spot" for the Volt (unless you are trying to hyper-mile) is in the 40-50 mph range.
Imagine the Bolt EV's range with a 160 kWh battery. If we're imagining why not go for 250 kWh?Imagine Ioniq's range with 60kWh batteries....
IIRC GM has said the greatest efficiency for a Volt was achieved at 28 MPH. It was a while ago so it might have been 38 MPH -- definitely an "8" preceded by a "3" or, more likely, a "2".Ari will probably disagree with your sweet spot. And unless you can post 80+ miles in a Gen 1 car, I'm gonna believe his number of 23-24 MPH being the sweet spot.
The CD is vastly over rated. Drive train efficiencies make a big difference as do other factors. Using the heater can make a bigger difference than CD, which I'm guessing is the case here.Bolt EV has a relatively higher CD (.3 vs .2x for other BEVs), which makes it more utilitarian but less efficient at highway speeds, especially at 80mph.
Engine on, or engine off? I'd be shocked if the most efficient speed in EV driving is over 30 mph without HVAC use, and 18 is more likely than 28.Imagine the Bolt EV's range with a 160 kWh battery. If we're imagining why not go for 250 kWh?
Here's the Gen 2 Volt's range as function of speed and temperature.Ari will probably disagree with your sweet spot. And unless you can post 80+ miles in a Gen 1 car, I'm gonna believe his number of 23-24 MPH being the sweet spot.
My wife drives our Bolt. I asked her about how the heater is affecting the battery range, as I posted in another thread was, "Who the hell cares? (laughing) I don't pay attention to gas stations or battery range anymore. I always arrive home with at least 90 miles to spare."Anyone who has lived through a cold winter knows heater use (especially resistance heating) dwarfs other factors regarding range (the only real measure that matters imo).
Yup, once you get rated ranges in the 200 mile range, any sort of around town driving is basically a non issue, having a small affect on your monthly electric bill but not much else.My wife drives our Bolt. I asked her about how the heater is affecting the battery range, as I posted in another thread was, "Who the hell cares? (laughing) I don't pay attention to gas stations or battery range anymore. I always arrive home with at least 90 miles to spare."
So there you have my scientific poll results, on how the resistance heater affects the Bolt's winter range![]()
By the way, if you want to see the high efficiency heater the Bolt uses check out http://gm-volt.com/forum/showthread...ve-element-or-heat-pump&p=4356689#post4356689
