1 - 4 of 4 Posts
So I have noticed that the entire podcast menu is missing when the iPhone is plugged into the Volt. This makes it impossible to select & play a podcast in the Volt. This needs to be fixed.
Skip the USB connector and use a standard iPhone/iPod 12 volt cable and mini jack audio cable. While not the fix you seek, it would allow the two devices to operate independently.
Strange because My 2012 doesn't exhibit this behavior. I have a Podcast menu (scroll down from initial displayed menu) and podcasts play fine. My only complaint is that you can't use the touchscreen to jump to a specific place in the track.
I found a kind of work around for the lack of podcast menu on the 2012 nav system: in iTunes, make a folder called podcasts (you will find make a playlist folder in the file menu) and then make smart playlists for each podcast and drag them into the folder. sync this folder and then you'll get playlists for each podcast in the car that will match your playlist settings in iTunes.
not ideal but it does work.
1 - 4 of 4 Posts
