1 - 6 of 6 Posts
Recently, I began receiving a "charging fault" whenever attempting to recharge the car after driving in the rain or visiting a car wash. Previously, this had been an intermittent issue that I experienced only after a heavy rain.
The charging fault was indicated only on the EVSE (charging station), and there were no error codes in the car. I knew that it was an issue with the car because the fault occurred on three different charging stations.
I took my Volt in to have the power inverter module reprogrammed, and also have the recharging problem fixed. The Volt specialist at the dealership had not encountered this error before.
As it turns out, the charge port receptacle had become loosened (although it was not visible to the naked eye), and would subsequently allow water in. In my case, there was also a crack in the back of the housing. The following parts were ordered and delivered the following day:
22975305 drive motor battery charger port receptacle​
22879633 charge port door housing​
The dealer gave me a very nice 1/2 ton 2014 Chevrolet Silverado to drive as a loaner.
G.M. advised the dealership that this has occurred on other Volts. If it is happening to you, you can have it fixed.
The cost to me was $0.00, and I am pleased with the service I received.
Line art Text Diagram Design Auto part
Which of the numbered items were replaced, James? I am guessing #1 and, uh, number 4?
Picture of a hairline crack in the back of the bakelite charge port
Revolver Auto part Engine
Hi Steverino,
All of the following were changed out:
22879633 charge port door housing: 6, 7, 8, 10, and 11.
22975305 drive motor battery charger port receptacle: 1, 2, 3, 4, 5, 12, and 13.​
I am getting an error message related to overcharging as well. I have replaced three outlets because of burn marks on each when I plug in my vehicle. I had an electrician install a dedicated 20 amp line hoping that would alleviate my problem. After five minutes it stops charging. I have talked to GM Canada about this and 'my' representative doesn't seem too anxious to rectify the situation. She consulted with her technicians as to what the problem could be and they suggested it may be because I don't have the charger mounted on the wall when plugged in!! I am very frustrated!
Premium Member
James, sorry you had the problem but glad you got it addressed. We've had reports and seen at least one picture before of a cracked housing. This is now my first thought when someone reports odd behaviors when charging, especially if they report a problem after a rain (my guess is the rain gets into the cracks).
Hi grannyblader,
What is the make and model of your EVSE (charging station)?
Thanks Don, that's what they said.
1 - 6 of 6 Posts
