81 - 96 of 96 Posts
Thanks so much for the video on the install. I just bought a 2014 with 35000 miles on her. We had her serviced at the local
Chevy dealer and the only rec's that came back were the 2 filters needing replaced. For a nice sum of $96 plus tax. Declined on that and did it myself.
Mine to had no cabin filter in her upon opening the compartment. Seems odd, and a scam by the dealer to do the install now on the "recommended" time frame of the car....
Not a scam. Gen 1 volts just didn't come with them. Any that have them were added by owners or at the request of owners.
Just picked up our "new to us" 2012 Volt. I will be putting in a new (or replacing) the cabin filter this very weekend.
Thank you for the Video and the other info.
Had my amazing 2013 Volt for 6 months now. Had no clue for the missing cabin filter, I just ordered one- AC Delco PRO CF1197C paid $14.12 from e-bay. Thanks to the OP for the instructions and pictures!
Update:
The easiest task I’ve done in quiet some time. The previous owner was aware and had placed filter /arrow up but still.../
Got it replaced in no time all you need is regular screwdriver and maybe some light.
Cabin air is different. Out of curiosity drove a day without a filter find noticed a significant air flow or noice from the vents.
After just shy of 35 months and 34K miles, I replaced my cabin filter. Once again, I went with the TYC 800149C carbon filter for ~$11 on Amazon.
Here's a pic of the old filter. The carbon leaves it a bit gray to begin with, but you can see a lot of dirt on it starting around 1/4 of the way down. I'm sure it costs a bit of efficiency, but that's crud that I wasn't breathing in.
Just checked mine after about 2 years since I put it in. Right now, it's still pretty clean. Admittedly I turn off the climate control system whenever possible, I prefer to drive with the windows cracked open slightly. The other 6 months of the year I'll use heat or AC.
hi everyone, after so many years, has anyone found a real HEPA grade filter or modification for 1-GEN Volt?
myne(2015 1 gen) had no filter, I got Denckermann filter but even i switch to inside cabin I still getting smoke smell from outside :/
maybe my car do not close valve ?
HEPA does particulates, not odor. Charcoal-impregnated filters help with odors, but don't/can't eliminated everything. I've got one of these
https://smile.amazon.com/dp/B00I8IU5DS/ref=psdc_15727101_t2_B00I8IU5EW
and I think it helps, but I might be fooling myself, because I still know if I'm downwind of someone's trash fire. On the other hand, it doesn't cost that much more than a cheap filter so ...
2018 Volt Premier w/ACC
That's right. Our 2013 premium trim Volt didn't have one. I put one using a Buick part at the time.
thanks, so you do suggest to get this one.
I was looking for a visual comparison between those air filter and cant find one, to really understand whats the difference.
even I choose to switch form auto recalculation to manual it does not work for me.(filter is installed) I still get air from outside :(
I already said I think it helps, but I leave room for that someone else might think it doesn't. I can't really make a recommendation that way.
HEPA ones typically brag about it. Charcoal ones have a thin but notable layer of black grit between two layers of filter, and tend to photograph as having grey paper instead of white.
That won't change, and it's working how it was designed to. The Volt's not an airtight submarine for *handwave* reasons. Mostly related to anti-fogging measures. This isn't the only such compromise, and there's a TON of threads arguing about why and whether it was good or necessary. The filter's after the intake though.
Not a scam, just GM being as cheap as possible.
O'Reilly sells one called Microgard. Less than 25 bucks. I'm tempted, but I can't find anything about the expect airflow of HEPA versus "regular." I've read a standard is about 1 stop on the fan, or about 6% more energy on my 2014. I'd like to know if HEPA is even more.
81 - 96 of 96 Posts
