Hey all - 1st time poster. Hopefully this helps another fellow Volt owner. We searched the web and forum for another post or recall on this issue but found no posts.
The Internal Combustion Engine (ICE) Upper Radiator Hose failed, and a slow leak eventually drained the coolant. The 1st Gen Volt does not have an engine temp for the display, only a MIL message 'Engine Overheat'. This happened to my son while he was driving, the head warped and resulted in coolant in the crankcase and exhaust. We had to replace the engine. It was a great Father-Son-Family project, but we hope to inform other Volt owners in hopes to avoid very expensive repairs. There is a plastic check valve in the hose that corroded and started to leak slowly, undetected. We recommend that the factory check valve is cut out and replaced with an aluminum valve. It is a $10 part, and easy to install. Shout out to cory151, his post was very helpful and inspirational! We will post pics and links soon.
