hello all,
I'm a little confused. Have watched a couple of reviews about the new BMW I3 and i don't know exactly how the range extender works. Some reviewers claim it works much like the volts. When the battery is depleted, the gas engine kicks on and powers the vehicle. In a volt, you can run out of gas, refill, and keep going. Hell, you can use the volt as a basic hybrid and never plug it in if you wanted too.
The I3 i'm not so sure about. Couple reviewers give the impression that it operates like the volt. However, a few reviewers say otherwise and i find their view more accurate. They say that the I3's range extender can only add about 70 miles to the overall range but YOU CAN'T just fill up the gas tank again and keep going.
Makes sense because the I3's engine is only a 600cc motorcycle engine. i don't think it could provide enough power to solely propel the vehicle.
In that case, i compare it to the volt in ERDTT mode. Ex, at -9 Celsius, right before the ERDTT mode kicks on, i can get about 40km's on pure EV power. At -10, ERDTT kicks on and my range can go up to nearly double (80km) in 'pure' EV mode. So i guess the I3 range extender works like that. It can increase range but can't solely power the vehicle.
I3 range extender version is estimated $10,000 more then the volt.
SOOOOO, if i'm correct and the range extender can't power the I3 like the volts system can, then the max range of the I3 is about 120km pure EV, volts is about 70, then with range extender, i3 max range is 230 km and volt is limitless! In that case, you can't drive the i3 (even range extender version) for more then 230km without charging it back up.
If this is true, why are volt owners here considering switching to an i3?????? your paying much more for, i believe, inferior product. Yes the i3 does have its own cool features that the volt doesn't, but so does the volt, and with a volt you have TRUE NO RANGE ANXIETY. an i3 would still give me range anxiety... i could never travel more then 230 km without charge.
I could be wrong, the i3 probably can run solely on gas, like the volt, but if not, why are volt owners even talking about it? Why so much hype around the i3 and so little around the volt?
